im Axle Specialists
Old 02-09-2021   #1
Battery charging questions
My wife's Mk 2 Punto doesn't get a lot of use at the moment and I want to charge the battery up before it goes flat, like it did last winter. Then, I disconnected both terminals (leaving the battery in situ) and it charged up fine. When it was reconnected, there was some odd warning light displays, which corrected themselves over time. Was this caused by the full disconnection? If so, is it ok to charge up while both terminals still connected? I don't want to cause problems either way.
RoyBGood is offline Reply With Quote Quote
Old 02-09-2021   #2
Re: Battery charging questions
It depends on your charger. A modern smart charger should be fine to leave everything connected.
A trickle charger will also be fine for leaving the battery connected.
Troubles with 500c is offline Reply With Quote Quote
Old 03-09-2021   #3
Portugal
Quote Originally Posted by RoyBGood View Post
Can you tell us what warning lights that come on?
What is the engine on that car?
I am not too sure that was caused by leaving the battery unplugged. I left my battery disconnected for 3 months once, and I did not get any warning lights.
crankshaft is offline Reply With Quote Quote
(T) Punto POP red battery light....battery is charging. Eireannbaker Other Fiats 3 10-11-2016 13:22
(T) Alternator ok, battery ok, battery not charging marc4242 Cinquecento / Seicento 7 25-07-2013 13:26
(T) Seicento Sporting 1108 Battery Not Charging Battery Light On SmithSeicento Cinquecento / Seicento 0 30-08-2012 00:02
(T) Battery not charging edumad Punto (Mk2/2b) 6 17-01-2011 17:22
(T) Charging a battery? MickeyBravo Bravo / Brava 5 01-03-2009 23:31
