Technical Spark Plugs
FiAt_PuNtO
UK
Hi, can anyone suggest a particular brand of spark plugs and a place to buy from? Fiat Punto 52reg 1.2 8v
I have got some bosch, tri electrode jobbies. £8 for four, and seem to work better than cheapass champion stuff.
NGK will give a cleaner burn, which in combination with a tuned engine and performance ignition system will allow some nice ignition tuning opertunities! Which may allow you to add a few HP (of course to a highly modified car, to a std or near std, its going to be barely noticable).
dave said:
i hate champion as well, what was wrong with yours?
Because they are no good.
NGK a very good but do not like fouling. Once this happens you need to change them as tghey tend to misfire, which can't be seen when you try to check whether they spark.
Denso is another very good make and so is Beru and Brisk. But don't bother to get Brisk as they are a nightmare to deal with.
I consider Bosch to be rather placed at the bottom end of the scale. Still Champion seem to be far worse.
