- Oct 6, 2018
- 39
- 65
Hi everyone,
I own a Fiat Punto mk2 from 2002 CVT which made a hissing sound whenever I turned on the air con.
In June 2020, I had the system re-gassed, re-oiled, UV dye added + some “leak sealer”. Back then I was informed the system was tight. (which I was confused about because the system was completely empty. It must have escaped somehow, right?)
Now, however, no cold air coming from AC again.
I’m not sure how long the UV dye lasts, probably washed away by now, but last night I checked the system with a UV light and couldn’t seem to find any trouble areas. Of course, I couldn’t see the evaporator as it is buried deep within the dash.
The hissing sound is exactly the same as this guys: https://youtu.be/nPqA7dLhaVo
I fear a new evaporator is needed, but the evap is located in a cosy interior place, so it would be the last item to fail I suppose.
Before I take apart the whole dash apart I just wanted to hear some second opinions.
Would you advice to just have en re-gassed again or would anyone have another way of checking out the evap?
