PoorlyPunto
- Feb 14, 2021
- 20
- 6
I replaced one of the headlights this week because it was fogged up/clouded and letting water in. I ordered a new old stock genuine Fiat one off eBay for £35. However when taking the headlight out of the box and removing all the bubble wrap, I found one of the mounts detached from the housing! Don't know if it was like that already or if I was a bit rough unwrapping it (I really don't think I was but can't be 100% sure).
I've fitted it anyway, and tried to get the broken piece to line up so it at least don't look broken (it is quite a clean break), but the results are not satisfactory as the pictures show it's obviously damaged. Also had to put a new bolt & nut on because the old one was cross-threaded and seized, so had to cut it out. Now the mount on the old headlight unit was partially broken and did pass the MOT, but it wasn't completely detached like this one is. Even if I can line it up better, they may still discover it's broken if they have to remove it to adjust the alignment of the beam, which I'm pretty sure needs doing. The unit itself is secure with no movement.
What do you think?
P.S How do I adjust the alignment?
Thanks in advance!
What do you think?
Thanks in advance!
