![]() | #1 | ||
Posts: 134 Thanks: 3 Trader Rating: 0 ![]() | MOT prep My 04 1.2 active sport is due its first mot since I got it. What are the common fails to look out for and fix before it goes in?
![]() | #2 | ||
Posts: 742 Thanks: 57 Trader Rating: 0 ![]() | Re: MOT prep Emissions atm...my thoughts why?...most of us arnt out and about doing the miles we 'used' to and subsequently the system doesnt get hot enough so the cat/o2 sensors dont read as they would under more normal circumstances, Use a bottle of catclean. Follow the instructions and before the MOT drive it like you stole it on a safe road so it gets nice and hot/clean before its tested. Air filter/plugs etc check and replace if neccessary. It wouldnt hurt none to spray carb/brake cleaner down into the throttle body either. Make sure its clean and seats cleanly in the bore. I use a toothbrush.
![]() | #3 | ||
Posts: 27,899 Thanks: 1094 Trader Rating: 0 ![]() |
![]() | #4 | ||
Posts: 134 Thanks: 3 Trader Rating: 0 ![]() | Re: MOT prep No underbody weak points?
![]() | #5 | ||
![]() | #6 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 ![]() | Re: MOT prep My '01 1.2 Mia got advisories in December for corrosion to underside and brake discs and pads worn. But I have seen some people get fails for underside corrosion.
![]() | Freebo | Cinquecento / Seicento | 20 | 14-11-2012 16:28 |
![]() | rushdentillidie | Punto (Mk2/2b) | 1 | 15-09-2010 20:30 |
![]() | richydraper | Cinquecento / Seicento | 3 | 07-09-2009 01:24 |
![]() | custard | Cinquecento / Seicento | 0 | 22-02-2007 15:51 |
![]() | SkinzCinqSporting | Cinquecento / Seicento | 16 | 18-09-2006 12:58 |
