Old 2 Weeks Ago   #1
Unhappy Fiat Punto 2002 1.2 8v won't rev past 3000rpm
Hi all, this is my first post here!
I've got an mk2 Punto 1.2 8v that won't rev past 3000rpm. It started last week after not being driven for a few weeks. It starts and idles fine, and sounds smooth like it normally does but when I hold my foot on the accelerator it just revs up and down between idle & 3000rpm, the MIL light comes on and goes out once the car returns to idle.
I got RAC out who plugged their scanner in which read P0302 (misfire on cylinder 2), he changed the spark plugs and HT leads because they were very worn but it made no difference. He said the ECU had probably been spiked and needed replacement, he also said he was getting electric shocks from touching the engine bay before the spark plugs were changed. I had the car towed to a friend's house who knows more than I do about cars, he plugged his scanner in and got PO351/2 (ignition coils), the misfire code is no longer there. Both coil packs have now been changed and still no difference, the PO351/2 codes lingered and after a bit of research, it did suggest that this is a symptom of a failed ECU, so I placed an order on Friday for a remanufactured 'virgin' unit costing £120.
I've now got the registered version of Multiecuscan and the PO351/2 codes have disappeared (even though I don't recall clearing them) and no errors are detected. I've been looking at the data under the 'parameters' tab. Two things that stand out are: "Throttle position" gives a blank % reading, and "Phonic wheel status" changes to "faulty" when I rev the engine but returns to "OK" when the car is idling.
From reading other threads on this forum this seems to relate to the cambelt? I've tried to do the self-adaptation reset and phonic wheel learn reset but on all occasions it just said "conditions not suitable" or something similar. In hindsight though I think I may have been doing it wrong, I had warmed the engine up until the fan kicked in and then pressed "execute" on the procedures while the engine was running but I think I should have run the procedure first and THEN started the engine and let it warm up before revving to 5000rpm 3 times. Can anyone confirm?
Also, before connecting to the ECU with MES, there are 3 different 'modules' in the list, and I'm wondering if I was connecting to different ones and if that would explain the error codes seemingly disappearing on their own without being cleared? I've attached some screenshots of the data in MES, the first 3 are with the car idling, the fourth is when I rev it and the fifth is the 3 'different' ECUs in the MES menu.
The new ECU is being delivered tomorrow but I'm really not convinced it will solve the problem. I'm trying to avoid installing it until other issues have been ruled out because once it's fitted to this car, I probably wouldn't get a full refund on it because it would have to be reprogrammed and "virginised" by the company before being resold. But with no other error codes being stored I'm not sure where next to go with this.
Can anyone offer any advice or share their thoughts?
Many thanks in advance!
Andrew
Name:	idle page 1.PNG
ID:	215625   Click image for larger version
Name:	idle page 2.PNG
Name:	idle page 3.PNG
ID:	215627   Click image for larger version
Name:	which control module.png
PoorlyPunto is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
Romania
Re: Fiat Punto 2002 1.2 8v won't rev past 3000rpm
I think the fault is the distributiin being out of sync. The belt jumped some teeth and this is why you cannot rev past 3000 RPM. At least this was the case many times before, you should check the distribution alignment.
Regarding the phonic wheel learn you did it right, kt should execute and then start the engine and rev it up to 5000 RPM 3 times.
I suspect there must be another problem at yours than usual, not reving past 3000 RPM (usual being the distribution out of sync) and that is the throttle positioning sensor. You say it stays at 0%, it should stay that only on idle, if it stays like that when you press the acceleration pedal is means it is at fault and that is why you cannot rev past 3000 RPM. Because the ECU does not "see" the throttle being open (sensor sending the reading of 0%) and so it not gives gas.
LE: after looking at the pics you've attached I see that "throttle angle" gives you the correct reading like 0.2 deg on idle and 25 deg on rev so the fault remains to be the distribution.
Likes PoorlyPunto liked this post
Mike1alike is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
If I am reading your post correctly then I have seen this before and the cause was the crankshaft position sensor.
Cheap and easy to replace.
Do check the cam belt and valve timimg as mike suggests too.
Let us know.
Jack
Thanks PoorlyPunto thanked for this post
jackwhoo is offline Reply With Quote Quote
Old 2 Weeks Ago   #4
Romania
Yes, by the term distribution I ment the timing belt that synchronizes the rotation of the crankshaft and the camshaft so that the engine's valves open and close at the proper times during each cylinder's intake and exhaust strokes.
Thank you Jack.
I used the term "distribution" because this is the usual term used in my language, Romanian.
Sorry, my bad as this term is not usual used in English.
Old 2 Weeks Ago   #5
Thank you both for your replies. I'm glad we seem to be singing from the same hymn sheet, it was the other fault codes that sent me on a wild goose chase. When you say check the cam belt and valve timing, is there anything specific I need to look out for i.e will it be obvious that something is wrong?
Also I am thinking of trying to do the phonic wheel reset again now that I know it should have been done before starting the engine. But would this have any effect if the belt is many teeth out of sync? If doing this got the car working I would be looking to get the belt replaced anyway, I am basically just trying to completely rule out a faulty ECU before I send the replacement back. The bit I am confused about is why there are no error codes stored relating to any sensors or the cam belt?
Thanks again for your help.
Old 2 Weeks Ago   #6
Change the crank position sensor.
It's cheap and easy job.
See If the engine will then run well enough to perform the phonic wheel relearn.
Then look at the guides how to change cam belt that will show how to check valve timing
Faulty crank sensors rarely set a fault code it's just the way it is.
Ps if you live anywhere with mice/squirrels check one hasn't filled your air filter with hay and nuts
Fuel tank full?
Old 2 Weeks Ago   #7
I'll try and get that checked later this week, the car isn't with me at the minute.
Can't post URLs yet until I've had 5 posts, but is this the sensor I need? - ebay.co.uk/itm/271525596881 (hope this doesn't upset the mods!)
My mate had a look in the intake to check for mice etc but it's clear and engine does the same thing even with the cover removed. Tank just under half full but as the car did less than 200 miles last year it's not had petrol put in for about 9 - 10 months! It gets turned over regularly just to keep the battery alive.
Thanks again.
Old 2 Weeks Ago   #8
Sorry, read that wrong. Is this the correct part? - ebay.co.uk/itm/233779208448
Old 2 Weeks Ago   #9
Romania
Quote Originally Posted by PoorlyPunto View Post
That is a crankshaft position sensor, yes, but check yours before you buy one. Maybe you'll find the part no. on yours and search one like that because the one in the link you've put looks different. At mine, Punto 1.2 8V 2006, the sensor does not have any cable, like the one in your link, it's just sensor and on it the plug for the cable.
It looks kind of like in this picture
Old 2 Weeks Ago   #10
Quote Originally Posted by Mike1alike View Post
Thanks, I'll check the part number before ordering anything. My mate spoke to a mechanic today and showed him a video he took of the car doing what it's doing, and he suggested it could also be the MAP sensor, what do you guys think?
Old 2 Weeks Ago   #11
varesecrazy has donated!
Thank you Jack.
You are correct
The ePER refers to it as 'distribution'
In UK english.. we have only just stopped using the phrase for Ignition
Where a 'Distributor' was in use for 100 years..
Distributing the sparks down the HT leads
Likes Mike1alike liked this post
Old 1 Week Ago   #12
chris3234 has donated!
I don't think you will have any luck being able to perform a phonic wheel relearn on a 2002 car as far as I know this is only applicable to the latest euro 5 and 6 engines with variable valve timing
A 2002 car shouldnt have this as far as I'm aware it starts around 2008-2009 with the 69 hp engine's
chris3234 is offline Reply With Quote Quote
Old 1 Week Ago   #13
Romania
Quote Originally Posted by chris3234 View Post
No, it is not like that. It is not applicable only to euro 5 and 6 engines as I've applied it on 2006 euro 3.
I think Andrew couldn't perform phonic wheel relearn only because he tried it with engine alredy turned on, hence the error "conditions not suitable". I really couldn't remember that detail that the engine must be turned off, but it makes sense. I figured it out while doing it and just forgot about it as there was no problem anymore.
Old 1 Week Ago   #14
Be able to apply it and it being needed are two different things did you have an issue with the timing being out?
Certainly not heard of an issue with the older not variable timing engines but perhaps I've missed it?
Old 1 Week Ago   #15
https://www.fiatforum.com/cinquecento-seicento/91258-phonic-wheel.html
Phonic wheel relearn has been around long before variable valve f.i.r.e engine came along.
(T) 03 punto active sport 1.2 8v won't rev past 3.5k Venox Punto (Mk2/2b) 2 06-02-2016 21:32
(T) HELP! Punto 60 won't rev past 4k! ianweaver Punto (Mk1) 19 12-06-2013 19:19
(T) Doblo 1.9 SX JTD 2002 - Wont rev over 3000rpm tommyvb Doblo 11 25-03-2012 22:49
(T) Seicento won't rev past 3000rpm! davesei Cinquecento / Seicento 5 20-11-2011 20:59
(T) seicento won,t rev past 3000rpm big cheese Cinquecento / Seicento 34 02-02-2011 20:54
