Styling Changing Punto Rear Tail lights
Brian Ború
Ireland.
Can anyone tell me what on Earth is the secret behind changing the tail lights in the back of the (2000 model) Punto ?
The Owners' Manual states to remove the bolt from behind the back seat, that holds the cluster in place and the next step is how to change the actual bulb.
But in the interim, how do you take the light panel off? - I'm afraid to apply force in case the thing smashes to bits !
Thanks guys - I failed to spot the bottom bolt - the picture in the manual wasn't totally clear. Probably should have used more patience aswell!
