Hi Guys,
I have been reading the forum a lot lately, because I have bought an MK2 Punto with the 1.2 v8 engine. The car has some problem what I can't seem to figure it out, neither my mechanic.
The problems are the following which are constant not intermittent.:
So far these things have been tried but nothing seems to work.:
Sometimes it is throwing the check engine light but as soon it is deleted it is hardly coming back.
First time around it throw: P0351 - Coil A, P0352 - Coil B, P0460 - Fuel level sensor circuit and P0303 - Cylinder 3 missfire. Because of that I thought that the ECU is bad so I went ahead and changed it together with all the ignition parts what I have listed. After I have installed the new ECU a bunch of new codes appeared.:
P0115 - Coolant temperature sensor, P0120 - Throttle pedal sensor, P0230 - Fuel pump circuit, P02D6, P3001, U1600, P0038 heater control circuit and a misfire code. After deleting the codes it is not coming back. (Maybe it was because of the new ECU I'm not sure)
I'm starting to have enough of this car so I really need someone's help, some ideas what this could be? Things I haven't checked yet: Compression and timing.
The car is not mixing oil and coolant and its not loosing neither of them. Please some one help me which direction I should take.
Doesn't have power, having a hard time accelerating and it doesn't go faster than 90 kmp.
Idles rough (gurgling), running on 3 cylinders for sure.
It doesn't really want to rev past 3500 rpm, not even stand still. As soon as it hits higher revs it is drowning and decreasing the RPM.
It has failed the inspection because of high emissions.
Changed HT leads (Bosch)
Changed both coil packs (Bosch)
Changed spark plugs (Denso)
Changed to a virgin ECU
Changed fuel pump, before the tank was emptied and filled with fresh petrol
