![]() | #1 | ||
Posts: 11 Thanks: 0 Trader Rating: 0 ![]() | ![]() Seen a few posts on this matter, some say twist and others say pull. No matter what I do, it just doesn't come off.. Anyone ever had that problem when it was really really tight? And how did you fix it ? Is it possible someone's super glued it down cause it really won't come off. Anyone got any clues on what I can do? Thank you.
![]() | #2 |
Posts: 463 Thanks: 16 Trader Rating: 0 ![]() | Re: Removing gear knob.
__________________ www.youtube.com/jonik1 |
![]() | #3 |
Posts: 4,121 Thanks: 125 Trader Rating: 0 ![]() | Re: Removing gear knob. Grip it with some water pump pliers and give the pliers a whack with a hammer. That's how I did mine
__________________ ![]() NOW ON ISTAGRAM #myfiatadventures |
![]() | #4 | ||
Posts: 26,429 Thanks: 1016 Trader Rating: 0 ![]() | Re: Removing gear knob. On such an old car it may well be a replacement.. thats been glued in place My nephews 16v had obviously had it removed to change the gaiter.. now it came off on most 2nd and 4th selections ![]() I used Epoxy.. : SOLID ![]() you may want to cut the knob down the sides and SPLIT it... if you have a replacement
![]() | #5 | ||
Posts: 3,271 Thanks: 162 Trader Rating: 0 ![]() | Re: Removing gear knob. Hair drier is your source of heat. If you are taking your knob off and replacing it with a different one, hacksaw is your chosen tool.
![]() | #6 | ||
Posts: 1,775 Trader Rating: 0 ![]() | Re: Removing gear knob. The knob does not come off so it screws back in place. If you get it off you have to glue it back on.
![]() | #7 | ||
Posts: 26,429 Thanks: 1016 Trader Rating: 0 ![]() | A 188 punto is not Its a tight fit from the factory.. and once forced loose..it will stay loose. This question has been asked for 18 years on here ![]()
![]() | #8 | ||
Posts: 11 Thanks: 0 Trader Rating: 0 ![]() | Re: Removing gear knob. Thank you to everyone whose responded, I will try a hair dryer or something with heat. If that does not work, I will go with the pliers idea and hammer it out. ![]()
removing gear knob | tom_c_miles | Lets Talk FIAT | 2 | 09-10-2015 15:23 |
![]() | glicopelotti | 500 | 0 | 18-06-2011 14:14 |
Removing the gear knob | number1golfer | Lets Talk FIAT | 5 | 27-09-2009 02:17 |
![]() | HiGGi | Punto (Mk2/2b) | 8 | 13-07-2008 21:00 |
![]() | BigSte | Bravo / Brava | 2 | 16-03-2004 01:54 |
