So it is from injectors then. Don't you think using a fuel additive that cleans them, before replacing them might do the trick and you'll not have to replace them? Although if they are broken, you will need to buy new ones. The good part is that new injectors work like a charm, the bad part is that changing them all at once would be a little expensive.
Well here is the plan...........
I got second hand fuel rail with injectors for £30 and I have an air compressor. The original injectors are currently sitting in cleaning fluid. I have made a tube to quickly block off the fuel rail feed using the quick release system and some spare parts. The plan is to put the original injectors back on the spare fuel rail. Fill up the fuel rail with injector cleaner by hand, block the filling/feed hole, fit the air compressor to the schrader valve, and then operate the injectors until the injector cleaner has all passed out the fuel rail thru the injectors at 3 bar.
I can also test the injectors if they spray ok eventually for equal amounts of fuel.
And if that does not work I guess i will be giving up!
