Technical Oil warning light when breaking
Hi
This should hopefully be a straightforward issue, the oil light (like a gravy or custard pot) comes on briefly when I have to break heavily. Then goes off.
1) Does this simply mean oil is getting low?
2) Or could it mean break fluid is low?
3) Can anyone top up normal oil or should I get garage to do it?
4) What type of oil?
Sorry so many questions but all important here, for me. I'm not technical, just a lay person, but wondering if I can avoid having to take it into a garage and incurring unneccessary costs.
Hi
Hi :)
Been a while since my mk2 188's
Ok.. back to basics
With the car OFF :
Turn the key to 1st position
What dash lights show
Probably ..
Yellow fuel blinks
Yellow emissions : engine block icon
Red Battery :a box
Red oil : a can or drip..
Red Brakes : (0) symbol
When you put your foot on brake and release handbrake
The (o) should go off
Handbrake back on
Start engine
Red battery will go off instantly
Yellow engine '' '' '' ditto
The red oil symbol should take a second or 2 to go out
Hope that is clear :)
Low fluids:
Brake fluid.. same light as handbrake (o)
Oil.. same RED engine light that took a second or 2 to go out ;)
If yours is a 1242cc FIRE prtrol engine then its not super fussy
SEARCH on here will tell you the specs
Brake fluid similar.. only Standard spec available
Brake fluid...SHOULD NOT BE LOW
It works like 2 linked syringes ..as you squeeze fluid out of one.. it fills the other
It should only keep a stock level..
Its either leaking..BAD
or you brakes have worn to the bare minimum
GET IT CHECKED..!!
Thanks Varsecrazy, I checked the system as you said, initially just turning key, then foot on brake and hand-brake off, then engine on etc - all the warning lights came on and off exactly how you predicted. So I think its just low on oil.
The wheezing sound I previously posted - yes mate only about a month ago though, when my exhaust started blowing and it had to be renewed, that happened as the bracket strap which held it had broken again (I reckon this is due to all the speed-bumps near me - and yes I do slow down for them, but obv not enough :)-) - anyway there must have been a slight hole in the exhaust as the car stopped making that sound at 55mph onwards instantly upon changing the exhaust.
Thanks again for your help! I donate a tenner each time, though I know its not much.
Europarts says 5W-40 or 10W-40.
I see you can buy it in 1-litre or 4 or even 5-litre tubs.
If I am just topping up do you think 1-litre is ok just to pour in?
Sorry again, I am technically & mechanically moribund & never fix or mess with cars but that is why I come on here for guidance :)-. Or is a bit more technical than that and I need to get garage to drain it etc?
