Replaced my head gasket and rocker and inlet/exhaust manifold + bolts about 7-8weeks ago, did a pressure test today and cylinder No.2 (from cam belt end) is down about 40psi on the others!!! I had head skimmed (£25 at uni, they do it for a living) and had used a decoke canister before I did it all too (it was very clean, either the decoke worked or the punto has a v.clean burn!), and not sure why this has happened?
Anyway, the other thing I have going is my clutch, bought a kit ages ago and a 6speed box to fit, already determined now that the clutch WILL fit the box, BUT I don't think I need a new clutch! Have driven two others puntos immediatly after mine this wkd, both with clutchs brand new (I know as I bloody did them, and BTW cable ties are a godsend, they keep all the ancillories tied up much better than string as suggested in manual ) and they both bite as low as mine, just mine seems to not actually engage better until much further up travel, I already determined that there was a leak down No.1 cyl end of block, But thought it was head or rocker gasket weeping, now am pretty sure it has come from crankshaft oil seal, Heres the question, COULD THE No.4cyl END OF ENGINE BE LEAKING OIL ONTO CLUTCH CAUSEING IT TO FEEL SO STICKY/BINDING AND CAUSE A BIT OF SLIPPAGE?? And if so where can I get a kit that incorporates the head gasket AND crankshaft oil seals??
thanks all.
thanks all.
