Old 07-08-2020   #16
Re: Power steering
I've moved on a bit with this now. After clearing the code and no problems for a while it stood and the battery went almost flat. I made the mistake of starting it and moving it on the drive. Light on and power steering lost.
Now has a brand new battery!
Keeps failing every time I clear it with the dreaded C1005
I've worked out it doesn't do it when steering right. Only left and mostly when reaching full lock but not always.
Obviously the Delphi reader isn't as good as MES so it looks like I will need to invest. Not sure if the free one will do this though.
I will get under and just check all the earth leads and such to make sure they are tight. Any I should pay particular attention to?
If none of the above I assume it's new column time?
Currymunster is offline Reply With Quote Quote
Old 08-08-2020   #17
Re: Power steering
Save your money on readers mate. I fixed mine by buying a torque sensor and getting rid of the old one. There's videos on you tube. All the sensors are the same just make sure they have the same plug as your old one.
BTW the cheapest sensor I could find was 50 quid plus 35 for shipping. You can buy a column for 68 quid and pinch the sensor out of that.
Likes Currymunster liked this post
markdarbypearson is offline Reply With Quote Quote
Old 09-08-2020   #18
Or swap the columns over and if yours is a mk2b 2004 just swap out the whole column with the 68 quid one and swap the motor and ecu over.
You may need to recalibrate the torque sensor and for that you will defo need MES and the license (50 quid) or find someone local who will do it 👍
Old 09-08-2020   #19
Quote Originally Posted by markdarbypearson View Post
Hi, I will look at the torque sensor but first I am going to try cleaning the multi plugs for the column. Won't cost me anything so I might as well give it a go.
Where have you found the column and sensor from mate?
Cheers,
James
Old 09-08-2020   #20
Re: Power steering
Hi James
By all means check the terminals but I am afraid its probably the sensor.
This is where I found the column (its for a mk2a but fits yours if you put your motor and ecu in it)
https://www.partsworld-uk.com/produc...lumn-mk2-punto
and here is the sensor that will fit
https://www.ebay.co.uk/itm/Torque-Se...-/282734717373
Hope this helps!!
If you need any advice I have just been through all this and will help if I can.
Trust me this was the cheapest option unless you are an electronics engineer and can repair torque sensors.
Unless someone else on here knows of an easier way?
Good Luck
Mark
Old 1 Week Ago   #21
Slovakia
Re: Power steering
Hi there. I have similar problem. After engine starts I barely touch a steering wheel and the red light comes on. After lots of reading on forums I assumed the steering angle sensor is broken. So I replaced it with the new one but problem persists. Does it need to recalibrate or something else ? Thanks for help
lego1234567 is offline Reply With Quote Quote
Old 1 Week Ago   #22
Re: Power steering
Quote Originally Posted by lego1234567 View Post
Yes I had that 2 years ago and was at its worst when starting from cold, I got the torque sensor error and ended up buying a new complete column.
But if not already test the battery and alternator to start with.
paul36 is offline Reply With Quote Quote
Old 6 Days Ago   #23
Re: Power steering
Right, I've bought the full version of MES now and have managed to check the battery voltages while running.
Brand new battery...12.6v standing
Idle..... 13.6
At 3000rpm .....14.01v
Still get the fault code c1005.
Now it would seem to me that the alternator is struggling to keep up.
Question is do I buy an alternator(?) or a streering column (85)
Old 4 Days Ago   #24
chris3234 has donated!
Re: Power steering
While a little low those values seem perfectly fine I'd that the battery
If they are the power steering ECU voltages they are very good
It could be worth cleaning the connections between the alternator and the battery and the battery and the earth cable with wire wool
But I'd be leaning towards the steering being a problem rather then a alternator
chris3234 is offline Reply With Quote Quote
(G) Fiat Croma 1.9 8v power steering failed - where to buy new power cable?? simonroscoe Croma 7 10-02-2016 20:43
Punto (Mk2/2b) Full Electric Steering Column & Power Steering Motor seaneb2003 Auction Watch 0 22-05-2013 09:14
(G) Fiat punto power steering (light on) steering rock solid OsamaBinLadin Punto (Mk2/2b) 5 13-01-2013 14:01
(G) Active Sport Steering gone really light.. power steering problem? andyleem Punto (Mk2/2b) 6 13-05-2011 11:59
(T) Power Steering/Power Assisted Steering Buffy Cinquecento / Seicento 5 30-03-2007 14:01
