General Head gasket leaking?
Do I need to replace my head gasket?
Oil coming from left and right (see pic)
That's not the head gasket it's the cam cover gasket.
Unsurprisingly there's a guide for it as it is a common thing to need to change:
https://www.fiatforum.com/punto-mk2-2b-guides/340549-1-2-8v-cam-rocker-cover-gasket-change.html
Head to shop4parts (currently out of stock!) https://www.shop4parts.co.uk/?name=store&op=Product&ProdID=7084
Although the MK1 part is in stock.
https://www.shop4parts.co.uk/?name=store&op=Product&ProdID=1205
I think the 1.2 8v engines are the same from the MK1 to the Mk2s? Someone please correct em if I'm wrong.
It's only the late MK2Bs that changed and are the same that went in the early GPs. If you've a square pull off oil cap then it's an early engine, if it's a round screw cap then it's a late engine.
On ebay: https://www.ebay.co.uk/itm/ROCKER-C...O-PANDA-DOBLO-1-1-1-2-8V-1999-on/130644776351
Take it apart.. clean faces..wipe over the seal
(Flip out the tin baffle too.. probably fithy under there)
Apply a little sealant / instant gasket
Reassemble.. all 4 bolts need only be 'snug'.. or you risk warping it :eek:
Do you mean wipe over the old gasket and add sealant onto that?
