Thread Tools
Old 5 Days Ago   #1
nitramtpr has donated!
ABS light on
Hi guys,
I've got an OBD reader on order, nowt fancy, one of these:
It's because I've got an ABS light up on the dash, no other lights and everything is working OK. I'm guessing (hoping) it's a wheel sensor at fault. Will the reader show the specific sensor at fault or will it just show there is a sensor failed?
Thanks, also is there anything else I can check in the mean time, the brakes are working just fine and dandy, zero issues (apart from the light of course!)
Hmmm, just been reading up on OBD scanners and it looks like the biudget friendly ones do not show ABS codes!
nitramtpr is offline Reply With Quote Quote
Old 5 Days Ago   #2
Re: ABS light on
So, after further reading and investigating it does indeed look like the basic readers do not output Airbag or ABS codes.
This looks to be the cheapest one out there that does ABS and SRS:
https://www.autelstore.co.uk/wholesa...stic-tool.html
Old 5 Days Ago   #3
varesecrazy has donated!
Quote Originally Posted by nitramtpr View Post
It says ENGINE CODE READER..
You want MultiECUScan
Where are you based ?
There is a register of members on here prepared to help out..
After so long on here.. I thought you would be aware of some of this
varesecrazy is online now Reply With Quote Quote
Old 4 Days Ago   #4
Re: ABS light on
Quote Originally Posted by varesecrazy View Post
I have been here ages and I did not know about the register, about time I became a registered member
Old 4 Days Ago   #5
Re: ABS light on
Im down near the M4..
But there are others in Yorkshire..and EastAnglia..etc
Old 4 Days Ago   #6
Re: ABS light on
I'm in Kent, right near the Channel Tunnel entrance, flippin' miles away from anyone!
I've got to get a new clutch fitted soon so I'll call my local garage up and see if they can run a scan for m, they're pretty good for doing little jobs for nothing if they're doing a big job.
Old 4 Days Ago   #7
judderbar has donated!
Finland
Re: ABS light on
I have one of those. ABS air bags. It would be fantastic if you could also turn things on as well, which multiecuscan does. It is convenient though.
judderbar is offline Reply With Quote Quote
Thread Tools
Bravo Speedo not working abs light on brake light and engine light domson1 Newbie Central 13 23-07-2019 13:26
(T) 1.2 elx 8v no speedo, no abs light, abs kicking in... Trodai Punto (Mk2/2b) 4 11-09-2016 20:35
(T) ABS light, DTS light, and ESC light on Cally 500L 2 05-02-2015 21:02
(G) No reversing lights / abs light / warning light Scudo06 Scudo 0 23-12-2010 16:44
Click, then abs light, then injector light, then cut out!!?? Tommy L FIAT Boo Archives 5 09-05-2006 14:20
