I have been reading past posts on battery drain and got about as far as I can.
My problem is with daughters Punto 1.2 8v active 2006. It has started draining the battery so much so that it won’t start most mornings.
Her problems started with the recent problem of the fuse for the stereo blowing ( 3 times now) so we have just left it out for now. Now the battery is draining over-night. I have done battery drain tests and have found the biggest drain from the Central locking fuse circuit ( about a 300ma drain), then I found the wind-screen wash fuse has a 100ma drain too. So i thought i should check the fuses under the bonnet and found the ignition switch on about 50ma drain with the dash board also draining about 100ma.
I intend to take out the stereo front cover when the tools arrive for me to do this, I guess it’s the original Blaupunkt stereo though so not expecting too much dodgy wiring but I am after clues of what items might be considered normally power drain and what should be totally off.
Then finally any clues of where to look first so I don’t end up taking the car apart looking for a rusty earth or something
TIA
TIA
