Ajay123
Hi all,
I have started to remove my gearbox prior to replacement on a 2004 Punto.
Not done this on this car type before so using a combination of Haynes manual and a Youtube video.
I've got to the stage of seperating the lower suspension arm from the strut so as to swing it out the way to remove the drive shaft.
However, with everything undone and jacked up the lower suspension arm is hard up against the end of the strut. Jacking up the hub doesn't help it just raises the car off the axle stands but does not compress the coil springs.
The video shows this as a really easy step but I cannot see what I am doing wrong and unsure how to progress.
Only possible options seem to be to either compress the coil springs in situ to raise the strut or completely remove the wishbone and refit afterwards.
Does anyone know the way around this?
Many thanks.
John.
Many thanks.
John.
