Drove the car last night and it was fine, parked up on the drive and shut down no problem. This morning car tries to turn over but wouldn't as if the battery was flat. However the Battery has a full charge and car bump started no issue. Went for a long drive got everything up to temperature everything working fine. Got home switched off and then turned the key to try again and got exactly the same problem. Tries to turn over but does so really slowly (not enough to fire) and then shows all the systems of a flat battery again.
Put a set of Jump leads on and tried again and same issue. Any ideas ?
