Hello I would be grateful for someone’s help. I have a 2004 5 door mk2b facelift 1.2 8v Punto. My mechanic is replacing my inlet manifold so I have bought a used one from a breakers with injectors attached. It says it’s compatible but when the mechanic came to attach the MAP sensor the socket on my replacement is different. The map sensor interface should look like the photo from my current inlet manifold
Does anyone know if there is a difference between mk2 and mk2b inlet manifolds ?
Thanks in advance [emoji4]
