The dipped beam in the left side does not work. The bulb is okay and so is the fuse. I tried switching the fuses left/right with nothing changed. The upper beam works fine.
There is no voltage on the wire. If I remove the connector and attach an alligator clip to the plus pole of the battery, the lamp shines nicely.
So I guess the wire is broken somewhere along the way to the fusebox.
But how do I find the right wire in the mess of wires under the hood?!
