I appreciate your reply and feedback Crankshaft..
The two thin wires appear to connect upto a bunch of other various branch of wires ... that appear to come from under the fuse box panel / or lower right dash inner relay section that is on the lower right hand side... and what I think are the other half of those wires were within a thicker Black Cable that seem to be within those other various wires... That I believe many of the other wires are to do with certain lights and also wipers..(That TWO Wires had been CUT ...and I have since reconected together)
Maybe I shoud try to take a closer up photo of that area if I can... that shows that black cable better and where those two wires NOW have been reconnected..
BUT I Myself do not really KNOW where that wire branch or the thicker black cable actually goes to...
I have taken out the various connections of various other wire branchs that connect to the inner fusebox / lower RHS dash board and removed the inner fusebox to try and see where those wires go to...
and I will be honest... I found it rather complex and hard to tell...
All I can seem to see is a few other bunches of wires all connecting various colored wires togther..as what I may describe as branches.. and they go in various directions underneath that lower area.... One goes to what I think maybe the right hand side lights... and I THINK that the branch that contains the Black Cable and the TWO wires... I think goes in a upwards direction.. that I assume may go into the bonnet or engine area somewhere...BUT I am Not really sure...
Could it maybe connect to some part that either connects to the engine or starter motor maybe ? or is their some computer somewhere inbetween the lower area and the bonnet to engine outer areas.....?
But It seems very hard to trace and if I recall the Black Cable may also be part of what was also a type of double branch where two lots of bunchs appear to join somehow... and one appears to bend off.. that has the black cable in it..
I was considering Taking out the Brown and Red wires out of that plastic terminal..
to see if I can make a more solid better connection... as just trying to bridge those wires using another smaller piece of wire... although it did appear to work...
or at least did appear to do so more on my later 2nd attempt... where I think it did make the motor or something continually operate or rotate if it was the Starter motor.. rather than just operate as one click at a time ...
but it was making quite a lot of sparking across the wires... So I thought that maybe by taking those wires out.. I maybe able to make a better connection to try and avoid the sparks..
BUT I note what you say... and I will consider trying what you suggest..
After what I described in ref to me attempting to bridge the two wires where I seemed to get the starter motor to continually rotate...I now assume the Battery has enough Power.... BUT I have NOT as Yet checked it for voltage.. as at the moment I dont have access to the right equipment...
You make a ref to the easiest way to make the car work... but I am uncleer on what you are trying to describe...
You say to use that PUG..... what is the Pug ?
I just hope that it is as normal and is not part of my problem..
In ref to this part of your reply...
I am not sure that I understand...
IF I have now managed to test those TWO (Brown and Red wires ) that come out of the rear of the ignition barrel or lock..
then yes I believe that I have proven that the Starter motor works oK...
BUT It will NOT work just by me trying to turn the key in the ignition lock or barrel.. and this is what appears to be my problem...
Is the problem purely due to the other TWO Front wires that connect to the front key side of the ignition barrel / lock... or where ever those wires go to..
or could there be some other problem within the ignition lock..
OR is it the or a computer / Keycode..problem
IF MAYBE the two front wires ... do go to the or a computer...Are they connecting to it OK when I believed that I reconnected the wires back together that the other ends appeared to come out of that lower Thick Black Cable that I referred to..
Or is the Ignition part... damaged that may somehow work in connection with some other parts of it... in that does the KEYCODE have some part built into the ignition lock that maybe could be damaged somehow..
or do you see it probebly likely that its a problem as to where the IG Lock two front wires somehow connect to an internal computer somewhere else in the car maybe seperate from the Ignition lock area..
If so where is the Computer likely to be ?
Would it be inside or maybe in the bonnet / engine area.. or directly connected to the engine ?
I think I did have a mechanic make some ref to them but I cannot recall what he said..but he did seem to believe that they would still work ok..
and was not part of the problem on trying to get the car to start.. which at the time I think I thought that they may had been my main problem.
I have to admitt that seeing them appear so burned out that you would think that what ever caused it has caused some serious damage..
as I would have thought that if the thick wires That I asume take a LOT more current or Voltage...than most other wires ..and appear similar to the thickness of battery wires... that to burn them out ... would have taken some severe damage to do so...
It was suggested to me that a 10 year old Kid did this to my car as the Ex Car Theif claims that he has seem this kid doing the damage to my car..
and he says although hes very distruptive that hes also very clever...
as I could not believe that a 10 yr old would be able to even do damage to my car in ref to what you can see in the photos...
Hes also broken all the windows...
But hes too young to prosecute and its proving it...and I am told his mother looks after him but is a drug addict..
When the ex car theft noted the thick wires burned out..... he also did not suggest that they were responsible for the car not working/ starting as I did point them out or he could easily see them when he had a look at that area..
I will try to reinvestigate more about what there are or do and how they have ened up appearing so burned out..
The thing is however that the other bunch of wires on the lower right side where the black cable comes out with them,,, many of those wires were also broken and some also appeared burned out...similar to the thick red ones... but I was able to reconnnect many of those wires back together either twisting the inner wires or using tape to hold them together ..
In ref to the mystery Cable.... IF you also have a similar cable that appears the same as what my photos and description is... then Hopefully that is just normal and the wire was never cut .. but it does appear to have been cut as the white cable contains what appeared as one thin but clear coated wire inside it...The easiest way to make the car work is to use that pug, so is better not to damage it too much.
In ref to the TWO Red THICK wires that are seeming Burnt Out...The easiest way to make your car work, is to use your key, with the ignition barrel you have.
In my view this is what you have to do:
Step one is to make sure you have battery to power everything and the starter motor cranks.
Step two started cranks with the turn of the key.
Step three sort out the wires going into the body computer so the KEYCODE function can work, and the engine control unit will make the engine run.
You want to remove the two wires at the top of the ignition barrel?
Those two thin wires are connected to the antenna, that is that plastic ring circling the ignition barrel. They connect the antenna to the car body computer. But in your picture they seem to go under a relay? where are those wires going to?
Your mystery white wire is another antenna, used to lock/unlock the doors when you press the key. At least in my car the Antenna is white, and is located there, and it looks like a wire.
Are you trying to remove the brown and red wires from the plastic plug, to get the terminals out?
If you are having problems doing that, I don't think doing that is a good idea, you could damage the terminal, or slacken it too much, and create a bad electrical contact when you refit it in place.
If you want to remove the terminals from the plug to have a better way to connect the Red and Brown wires, instead try this:
- Disconnect the battery negative (black one) terminal.
- Put a paper clip, in the plug, connecting red and brown. Make sure the clip doesn't contact any metal part from the car.
- Car in neutral
- Connect the battery negative terminal
- Does it crank? it should crank right away, and you could see some sparking when you reconnect the battery terminal. As soon as you observe it cranking or no, disconnect the negative terminal again, and remove the paper clip.
If it doesn't crank the battery could be dead. Starter motor could be broken. But I would put my money on a dead battery. Did you check the battery voltage?
The car only needs the RED and BROWN together to crank the engine, and fuse F3 must be good, nothing more, no relays or anything.
The car will crank, but it won't start because the engine control unit won't make the engine run.
This could also be a symptom of a battery with a low charge. Please make sure your battery is good. Test it with a multi-meter.
BTW do you have any ideas why those 2 thicker cables are burned?
They are both 12V+ wires that come from the engine fuse box and power up everything in the interior fuse box.
