Thread Tools
Old 18-08-2019   #1
neilhaj has donated!
Leaking pipe? What is it?
Hi
I have just drove 100 miles and after parking up and emptying car noticed a load of fluid leaking from the engine, on closer inspection it looks to be leaking from a pipe and hopefully just a loose jubilee clip.
What pipe is it and what fluid is it carrying?
Photo shows where the leak is (circled) and I've highlighted the pipe with a red line
Thanks in advance
Neil
neilhaj is offline Reply With Quote Quote
Old 18-08-2019   #2
Update the liquid is blue / green so I'm guessing coolant either way RAC are on their way. I'll keep you updated
Old 18-08-2019   #3
varesecrazy has donated!
Re: Leaking pipe? What is it?
Hi.
Line is a coolant hose..
Circle is a cable: electrical.. lambda probe
I suspect..
Your issue is actually the steel tube the hose is joined to
It plugs into the waterpump.
Behind the plastic engine timing cover.
Old 18-08-2019   #4
RAC can't repair and said it need to go garage to have metal pipe replaced, I'm on holiday 100 miles from home and don't really want to take it to a unknown garage.
Would some epoxy putty do the trick as a temp fix until I get home? Has anyone got any ideas or recommend a garage in York area that can fit me in tomorrow?
Old 18-08-2019   #5
Quote Originally Posted by varesecrazy View Post
Hi.
I suspect..
Yes you're right it is the steel pipe! He's put some sort of gasket sealant on and told me to top up tomorrow with water and take to nearest garage, I'm in York on holiday for 4 days and need the car to get around! Any quick temp fixes?
Neil
Old 19-08-2019   #6
judderbar has donated!
Finland
Talking Re: Leaking pipe? What is it?
Quote Originally Posted by neilhaj View Post
Neil
You can buy a few products to add to the coolant which can work on a smaller leak.
If the leak is actually where your circle is then it could be fixed by cutting the damaged end off the pipe and adding extra tubing with a join in the tube. Adding gasket sealant to the outside of the pipe seems doomed to not work.
If the metal pipe is actually good then the fix is simple and you can do this yourself with a knife and the tube and connector from a motor shop. You appear to have the original clip there which can be broken off using a screwdriver jammed into the retainer.
Otherwise if you carry masses of water you have no major problems providing you keep filling it up!
Thanks neilhaj thanked for this post
Likes neilhaj liked this post
judderbar is offline Reply With Quote Quote
Old 19-08-2019   #7
thanks. The hole is in the metal pipe and not the rubber one. The sealant has worked and it's no longer leaking, hopefully it'll last till I get home. We're here till Thursday and I've rang 3 garages this morning and none can fit me in until Wednesday.
Old 23-08-2019   #8
So got this repaired and now the bastard bonnet won't open argh.
I've messaged Dave to see if he's still active so I can donate and get the photos.
Thread Tools
(T) engine coolant pipe leaking TONY55S Punto (Mk2/2b) 8 10-06-2018 19:52
(T) Leaking fuel pipe redvtec Stilo 1 16-02-2018 18:50
(T) leaking fuel pipe flisko Punto (Mk1) 5 12-07-2016 00:02
(G) leaking powersteering pipe!! andy ilsf Marea 3 02-06-2010 20:40
(T) Unknown leaking pipe, help please! sidjoloo Cinquecento / Seicento 2 04-11-2006 19:05
