FIAT Auto Specialist Team
Old 20-07-2019   #1
Croatia
1.2 16v to 1.4 16v swap, Help!
Hello everyone, my girlfriends sporting's engine has died so as I could not find an replacement 1.2 16v engine, went for the 1.4 16v Stilo engine. The engines are identical and the swap was pretty straight forward but when I wanted to start the new engine it just turns over and does not start. The fuel and spark are there but does not start at all. The old engine did not have the cam sensor so I just left it unplugged. Used the old wiring loom and ecu. Any suggestions would be appreciated, thanks in advance!
noDi is offline Reply With Quote Quote
Old 21-07-2019   #2
judderbar has donated!
Finland
Re: 1.2 16v to 1.4 16v swap, Help!
Quote Originally Posted by noDi View Post
1. The cam sensor is only used to help the engine start in fewer starter motor rotations so that change can be ignored.
2. The fuel descriptions inside the 1.2 ECU memory cannot be exactly correct for the 1.4 engine but that might not be a huge problem as regards not starting.
If you have a tachometer it should read about something like 200 revs per minute when starting. I forget. either 150 or 250 revs when starting. It may be necessary to install the 1.2 crankshaft sensor to ensure you do not have an electronic mis-match between the currently installed 1.4 sensor and the different 1.2 ECU. But since you have a spark that does not seem to be the problem.
Otherwise I am assuming you would get the engine at least to do something other than do nothing.
You need to follow standard troubleshooting otherwise. Do you have any fault codes? presumably not. you need to check for OBDII codes anyway.
Did you see the 1.4 engine running or know its history?
judderbar is offline Reply With Quote Quote
Old 21-07-2019   #3
Croatia
First of all, thanks for the reply! Today I tried replacing the crank sensor and pulley and still no signs of life. There are no obd fault codes stored, checked with an generic obd tool. The problem is i did not see the 1.4 engine run, took it out of a crash damaged Stilo that supposedly was running a month ago. Starting to think the engine itself is at fault but it should show at least some signs of life. The old engine was burning a litre of oil per week and was working on 3 cylinders but fired up right away. 😐
Old 22-07-2019   #4
Finland
Potentially the valve timing via the rubber belt driving the camshaft could be altered by the engine stopping suddenly in a crash. So check the valve timing.
Old 22-07-2019   #5
Croatia
Quote Originally Posted by judderbar View Post
The timing marks on the cam and crank are dead on, the belt looks new. Overall state of the engine seems really good, it was obviously well maintained. I'm starting to run out of ideas . Wanted to send a p.m to a few members here who I guess did a similar swap but can't... Probably because I'm a newbie... @m20b25 and @dave
Old 22-07-2019   #6
Finland
On a 16v engine there are not timing 'marks' as such. the timing can be wrong when the cam is correct and the pistons are level.
I am not now sure if number 1 piston needs to be on the down stroke or the up stroke. I think on the down stroke.
Potentially the engine could be incorrectly timed and then sold because of failure to start when it just needs to be correctly timed
Either way on the 16V there are no official crankshaft timing marks
Old 22-07-2019   #7
Croatia
Just talked to a local engine swap "guru". He says that I need to put crank pulleys on both engines, put the first piston in tdc and then count the number of teeth from the pickup to the "0" on the pulley. He says that it wil probably be off/late by 2 or 3 teeth so I will need to widen the bolt holes and adjust accordingly. Does that make sense? The engine does give the symptoms of late ignition...
Old 22-07-2019   #8
Finland
The small hole in the crankshaft pulley should be over the raised 'dimple' in the crankshaft. There is no 0 on the pulley. I suppose you are talking about the area without teeth
Why does your guru think the crankshaft pulley could be incorrectly positioned by a few teeth? What logic is he using to believe it is possible?
The crankshaft pulley is correctly positioned for the ignition timing. The pulley under the crankshaft pulley is correctly positioned for valve timing when using the approved fiat method that does not use the position of the crankshaft to set the timing!
Why do you have late timing symptoms? You said you had no firing?
Why do you not have crank pulleys already on both engines??
Old 22-07-2019   #9
Croatia
By 0 on the pulley I mean the part that has no teeth. I removed the pulley from the old engine to compare them but found very little diffrence. Tried starting with each one with same results. The crankshaft does not have a dimple but a 3-4mm hole that alignes with the same hole on the pulley. The engine occasionaly "backfires" through the throttle body... Btw thanks for replying so quick
Old 22-07-2019   #10
Finland
And you are sure you know how to correctly do the valve timing?
Old 22-07-2019   #11
Croatia
I myself did not interfere with timing on any of the two engines. Did a bit of reading today so if you can confirm this; the 1. and the 2. piston have to be mid-stroke and the slots on the intake and exhaust cams have to be in the middle of the holes in the side of the head. That means the engine is timed correctly? Am aware that there is a special tool kit involved and I won't be adjusting the timing without it. The up side of all this is it will make it easier for me to do the timing belt replacement on my Giulietta MA
Old 22-07-2019   #12
Finland
Your timing instructions are not complete (as i mentioned earlier) You can have the mid stroke of 1 and 2 before top dead centre or after top dead centre. It is possible, as i said, for the previous owner to have failed to start the engine because he incorrectly timed the engine and then gave up and sold the engine.
The highly regarded Haynes manual fails to mention which of the 2 different piston positions is required. Many people have timed the engine with it 180 degrees incorrect. Number one must be half way down on the down stroke.
Old 22-07-2019   #13
Croatia
Yes that was the one thing bugging me, Haynes just says mid-stroke. If the timing is really rotated 180 degrees could it mean damage to the valves? And could the engine be started by switching the ht leads (1-2, 3-4)?
Old 22-07-2019   #14
Finland
The engine is not damaged if 180 degrees incorrect. Changing the ignition leads cannot help the situation.
All you have to do is turn the engine with somebody looking thru the cam lock hole at the front of the car till the flat slot on the camshaft appears. Number one should then be half way thru the down stroke.
Old 22-07-2019   #15
Croatia
Get it, thanks for your time! Tomorrow I'll be spending some quality time with the punto and will post the results...
(T) Instrument panel swap 1.4 16V to 1.2 16V kido resuri Punto (Mk2/2b) 3 07-01-2018 00:28
(T) Fiat bravo 1.2 16v, swap to 1.6 16v Cro_Tom Bravo / Brava 29 16-05-2011 23:48
(T) Engine Swap 1581 16V to 1596 16V - Is it possible? Hnopo Marea 5 14-01-2010 00:21
