Thread Tools
Old 10-07-2019   #1
Macedonia
Air Con Fan will not shut off
Air Con on the fiat punto classic Mk2 Mjet 1.3 cools well but the fan will not shut off when I turn off the air conditioner or I turn off the car .... the engine temperature is non-stop 90 degrees ... this just happens when the air is working a long time.....pleas help
ninosio is offline Reply With Quote Quote
Old 10-07-2019   #2
Re: Air Con Fan will not shut off
Which fan are you talking about first off, the engine fan or the fan in the cabin ?
Also if you get out and turn off the car the fan may be expected to run for a little while to cool everything down once you have switched off the car.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 10-07-2019   #3
Macedonia
motor fan ... when I switch on the air conditioner it will Fan normally turn on ... but there is a problem that will not stop later ... when I do not start the air conditioner, everything is ok
Old 10-07-2019   #4
Trader Rating: 1
The Panda Nut has donated!
Go get the air con gas pressure checked as a fisrt step. If its got pressure its an electrical thing.
If your air con condenser has sprung a leak - which is quite possible it will need a new one. They are about £100. (I had our Panda one changes a month back) A gas recharge at my dealer was £28 for the gas. If the system is trying to cool and there is no gas the fan will run on. Labour was 2 hours approx. Good luck.
Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼
The Panda Nut is offline Reply With Quote Quote
Old 10-07-2019   #5
Macedonia
when I hit a box with fuses under the bonnet, the fan turn off
Old 10-07-2019   #6
Quote Originally Posted by ninosio View Post
Sticking high speed fan relay then
Likes Brendan W liked this post
Old 11-07-2019   #7
Brendan W has donated!
Ireland
Quote Originally Posted by AndyRKett View Post
Which might start you thinking that the current is a bit high and maybe the fan itself is sticking?
Check how free it turns, motor stone cold and keys in your pocket and battery disconnected
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Thread Tools
(T) Air Con Fan Angler JAY81UK Punto Evo 1 20-05-2019 21:26
(G) Ducato air con fan , where to buy? Fiat Gold Coast Suns Ducato 1 04-05-2014 15:25
(T) Air Con fan not working Help! slunkeh Grande Punto 8 09-08-2012 09:36
(G) Air Con/Fan Problem The Prof Ulysse 7 11-06-2006 14:02
no fan and air con! HELP!!!!! simon FIAT Boo Archives 1 12-11-2003 09:58
