Thread Tools
Old 09-06-2019   #1
sandaru has donated!
Sri Lanka
Lambda sensor closed loop only when manually grounded
Hi my Punto speedgear 2000 is fitted with new cat and new lambda but it does not go closed loop normally and stuck around 0.475 volts with open loop. But when I manually grounded the ground wire from wiring loom it goes closed loop and can see mostly the fluctuations above 0.450 volts. Please advise.
sandaru is offline Reply With Quote Quote
Old 09-06-2019   #2
Hungary
Re: Lambda sensor closed loop only when manually grounded
Check the ground cables, to the ECU, between battery negative and gearbox, chasis.
Thanks sandaru thanked for this post
Likes sandaru liked this post
kido resuri is offline Reply With Quote Quote
Old 12-06-2019   #3
Sri Lanka
Those connections are there and they are very clean with no dirt
Old 12-06-2019   #4
Hungary
Try to measure the wires from the ECU to the lambda-sensor. Whites are the heater, you should measure 12V voltage between the two, the grey should be ground and the black is the ECU input.
Old 27-06-2019   #5
Sri Lanka
Is it ok to manually ground the ground wire to keep the sensor closed loop when engine running?
Thread Tools
(T) Lambda probe in open loop Modano Tipo (Classic) 7 26-05-2016 17:52
(T) closed loop disable or Lambda value change TurboCinqy1250 Cinquecento / Seicento 13 15-05-2009 20:10
acceleration flat spots & lambda light,....MAF, lambda sensor, fuel pressure regulator,.?? nico FIAT Boo Archives 0 10-07-2008 19:56
(T) lambda sensor open loop ? ycming Cinquecento / Seicento 6 08-06-2007 20:24
