Technical Lambda sensor closed loop only when manually grounded
Hi my Punto speedgear 2000 is fitted with new cat and new lambda but it does not go closed loop normally and stuck around 0.475 volts with open loop. But when I manually grounded the ground wire from wiring loom it goes closed loop and can see mostly the fluctuations above 0.450 volts. Please advise.
Try to measure the wires from the ECU to the lambda-sensor. Whites are the heater, you should measure 12V voltage between the two, the grey should be ground and the black is the ECU input.
