Hello
this is my first post here , i hope it will not be the last
I have searched but didn't get clear answer.
I want to do 2 MODS.
1: I want to connect my chinese alarm unit with the door to know if the any door is open
from the wiring diagram,
( check this screenshot )
i have connected the mentioned wires with the wire of alarm , but i didn't get the proper result.
so which the right wires should i connect?
( my version didn't came with any alarm model but has central lock unit )
2: with the same chinese alarm i want to when i lock the car with remote ( it's working good now ) i want the windows to be closed.
the alarm unit has this wire , but i don't know to which wires should i connect as i don't have up unit to auto close the windows i have 2 buttons in my interior that are closing the windows manually when it's only the key is Ignition switch on .
i guess it will not close the windows as the key will be off the car at all.
