Technical mk 2 punto emissions failure
hi,
my 2000 reg punto failed emissions test today.
The results were high idle 2770rpm CO 0.50 vol%
Anything above 0.30% is a fail.
Is it worth changing the lamba sensor?
i have been getting a misfire now and then ,but then it clears
any ideas before i scrap the car?
tony
Also i have to keep topping the car up with engine oil recently.
Would this be a sign of worn guide valve seals?
tony
I am fairly sure its the intermittant misfire that is causing the emissions to fail.
I have changed leads,coil pack ,plugs,and the fact the car is using oil leads me to think something in the engine has worn out since it has 150k miles done.
I removed all 4 plugs last nite.
Starting from the left side of the engine as you look in,
the first 2 plugs were a dry whitish colour,and the last 2 were fairly black
with bits of soot which i cleaned off.
tony
Might be worth swapping the injectors from that side to the other and see if the plug colour moves. As mentioned already a bit of injector cleaner could help.
If it was worn out I would expect the black plugs to be wet rather than dry.
A compression test would be the next thing to try.
