Hi guys
Having a bit of trouble with my sisters car. Did a lot of searching here, but I would like your advice. The car is a 2002 1.2 8v 188A4000 with 160.000 miles (258.000km on the clock). Probably seen better days, needs its tappets done, but until now actually ran pretty great :spin:
Well, the main issue now is that it is not running right, misfire/not running on all cylinders I guess. Plus it vibrates and idles really rough.
My sister has only been driving it for about 2500 miles (4000km). When we first bought it, it had just had it's cam belt changed and I presume a headgasket replacement. Valve cover gasket is a little leaky as usual, havent gotten around to sorting that yet. It does not loose oil though, coolant is fine too.
I changed the sparkplugs and HT leads because they were old and crusty, and it ran fine (aside from tappets noise), until now. No power, rough idling and poor revving/power. It does drive, but barely, and the engine light comes on flashing almost instantly.
Thought it was the coil packs. I did change them, but it didnt help. But aren't the readings on the ohm-meter weird? Old VS new:
Old:
New:
Made a video of the car idling- http :// surl(dot)dk/huu/ (cheat link, I know sorry, cant post links yet. Maybe a moderator can verify it) Notice vibrations by alternator and motor mount.
Any ideas on where to go from here? Dont really know what to check. Although I am going to check the sparkplugs for cracks, didnt think about that yesterday. Probably gonna put a tester on it too, but I dont know how helpful that is going to be. I am really leaning towards a used engine, seeing that the tappets are also in need of repair. Dont know if the engine is worth spending a lot of time an energy on.
Old:
New:
