- Jun 16, 2017
- 135
- 36
Im having a small problem with my dashboard warning lights in my mk2b 5door.
Every time i press the brakes a yellow warning light for lights comes on.
I had this one time before (christmas efect) when i had a corroded ground pin on one of my rear lights,cleaned that and fixed it.
This time i checked all my rear lights, no corrosion(still cleaned it even more), all the lights work as they shauld, even brake lights work normaly when i press the brake. The warning light is always there when i brake, the lights always work properly, tested for 15minutes and every time everything worked fine. What shauld be causing this problem?
