OP OP R robt New member Joined Dec 27, 2014 Messages 29 Points 7 Feb 11, 2019 #21 Hi - yes it does! There is only one lambda sensor - is that correct?
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,976 Points 7,834 Location Near the M4 Feb 11, 2019 #22 robt said: Hi - yes it does! There is only one lambda sensor - is that correct? Click to expand... Normally 2 ... either side of the cat.
OP OP R robt New member Joined Dec 27, 2014 Messages 29 Points 7 Feb 11, 2019 #23 Thanks - Yes - i've just read that the front manifold one is the important one - quote "Under normal circumstances, the rear sensor does not have any direct impact on the fuel mixture (and therefore the running and emissions of the engine)
