Yesterday I was called by a friend if I could have a look at his dad punto mk2b with a dualogic gearbox. He parked the car in front of his house and when he wanted to leave next day he was not able to start the car.
I haven't driven the car and have no prior experiences with the dualogic so I do not exactly know what normal behavior is.
The starter is not engaging, when you put the key in the MAR position the display it shows check for a couple of seconds and after that there is no message anymore but you cannot turn the key to activate the starter.
If you do not wait for the checking to complete and turn the key to the start position nothing happens, releasing the key it comes back to MAR and again you are not able to turn to the start position again.
The car is in gear, according to the display it is first. When you try to change gear to neutral, reverse or from auto to manual the buzzer makes a sound and displays that the gear is not available and after a while is shows defect gearbox.
the box has been rebuild just over an year ago and did not gave any problems or indications of possible problems earlier. Of course it just out of warranty.
- I checked if the break lights come on when pressing the pedal, they both come on and I do not see any signs of shortage.
- I disconnected the battery for a couple of minutes, this did not help
- according to my delphi odbc reader there are no faults stored in the system. (I tried multiscan as well but I have no experience with the tool and used the free version. Multiscan did not show me any problems)
- tried to jump start the car using jumper cables from a running car.
I thought that I heard the hydraulic pump running but now I think that I confused the fuel pump sound for that. I heard the sound every time I turned the key to MAR.
According to some posts here the hydraulic system gets primed when opening the driver side door.
How is this registered? is this the same make / brake contact as for the interior lighting? And how often is the system primed?
As I think of it the interior light did not always come on opening the door. The door catch itself seemed broken.
Can I check if the hydraulic system gets pressurized and can I manually put power on the pump if it does not get pressurized?
How do I check the oil level of the gearbox? Do I need to remove the aluminium heat shield for that? And is there a special procedure to check and fill if required?
Are there wiring diagrams somewhere to be found that would help a lot in fault finding.
And is there a manual way of putting the box in neutral or disengage the clutch so I can safely transport it?
I know, I have lot of questions but hopefully somebody can help me out. I tried the search which helped me a lot already.
