luqluq
Hi guys,
Need a help here for my Mk2. My Fuel pump is not working. Checked voltage thru cable, reading is none when switched on. But when switched off, it showed a blinking 12V for a split second and back to 0V.
Searched thru the forums and found some suggestive ideas:
1. Check for cut off switch.
My question: Where is the exact location?
2. Check for fuel pump relay.
Your help(s) is(are) greatly appreciated.
Thank you.
Luqluq
Thank you.
Luqluq
