Technical Rear orange indicator bulbs - what type ??
Punto Mark 2b 2003 model.
Anyone know what type of bulb this model uses in the rear indicator bulb unit ?
Need to change both rear indicator bulbs.
I thought is was PY21W but when I put that into ebay & Amazon vehicle checker it states the following:
This doesn't fit a Fiat Punto 2003 188_ [1999-2012] Hatchback Hatchback 1.3 JTD 16V 1248ccm 70HP 51KW (Diesel)
Confused
Handbook page attached.... so without dismantling the whole thing cant check if it has offset or non offset I assume as even that does not clarify what I need.
When I check P21W it also says:
very confused
very confused
According to my local shop it is clear you need a P?21W bulb but it is not clear if you need the 150 degree offset or the yellow!
Usual policy is you take away the possible bulbs and get a refund on the ones you bring back. The bulbs are not expensive.
