Old 28-11-2018   #1
Load sensing valve on rear axle
I have a Fiat Punto Dynamic 2002/3 model and the rear axle load sensing valve is weeping. I all so have as spares another punto which is two years younger and that one do not have a valve fitted now can I do away with the valve on my veh I know what is for but I dont see the point when one has it and another dont , any help please.
Masseyferguson is offline Reply With Quote Quote
Old 28-11-2018   #2
Re: Load sensing valve on rear axle
Your newer one will have ABS so does not have the valve.
They can be quite costly
I managed to get a bosch unit from a motor factor for about 55 and fitted it myself
Only had problem with 1 brake pipe being seized.
It will not pass a MOT if you remove it.
part number is 0204031180 from Bosch
Del80y is offline Reply With Quote Quote
(T) load sensing valve seized Mighty2000Mouse Punto (Mk2/2b) 13 30-11-2018 22:06
(T) Load sensing valve hcloseuk Doblo 0 20-05-2018 19:41
(T) 1988 ducato rear brake sensing valve linkage MAUBRI Ducato 7 14-12-2016 12:57
(G) Ducato rear brake load sensing valve setting plate . wheelnuts Ducato 1 03-11-2014 20:51
(T) brake load sensing valve steinar Punto (Mk2/2b) 1 06-11-2008 12:29
