Old 23-11-2018   #1
Exclamation load sensing valve seized
Had my MOT today and failed due to the load sensing valve being seized and have a few questions
Where is the load sensing valve?
Is there an easy way to fix if it is seized?
What would the cost of a new one be?
Rough price of a garage doing it?
Thanks in advance
Mighty2000Mouse is offline Reply With Quote Quote
Old 23-11-2018   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: load sensing valve seized
Load sensing valve on the rear axle
The more weight in the rear of the car, the more fluid is allowed to the rear brakes to help with stopping
Only Non Abs puntos got it as they removed the restrictors on the master cylinder that the mk2 got
New isnt cheap based on Euro Car Parts prices
Labours gonna be high, i dont think many will have brake lines that will survive been removed as there right in the firing line.....
And if your lucky - just hope to god the rear cylinder brakes dont snap there blees nipples off....
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 23-11-2018   #3
A brake fluid change may help before you go any further. I suspect is quite hard for MOT guys to tell the valve is seized. Worth asking what they seen. Do the rear brakes work at all? or are they locking all the time? Do the rears have even braking?
dumbledore is offline Reply With Quote Quote
Old 24-11-2018   #4
Burkina Faso (Upper Volta)
there is a metal pivot that works from the load sensing valve to the back axle
if you look under the back of the car on the offside axle you should see like a metal pin going down connected to the valve body
the pins seize due to the valve not getting any use unless passengers are carried in the back often
if it is seized give it a good dose of anti seize spray and leave it to work its way in,repeat over the next few hours
then carefully try manually frreing it
be aware if its all just a lump of rust then the valve itself will leak brake fluid and thus be dangerous
they used to be about 75 from andrew pages but they have 4 brake pipes going into them and as suggested by ziggy? these often do not want to come out so a garage would want to replace all these pipes
if so the bill unfortunately will be very large
s and b is offline Reply With Quote Quote
Old 24-11-2018   #5
Quote Originally Posted by s and b View Post
Kinda glad mines been slammed to the ground with towing / loads for the tip regulary
If you ever use spring assistor on the rear... like i did for towing... its okay when towing but off was horrible... rears did jack ****e....
Ziggy
Meet Bumble-Bee
Old 24-11-2018   #6
Quote Originally Posted by Ziggy122 View Post
Ziggy
Thanks for the reply. What did you search to find the part because I can not find it anywhere
Old 24-11-2018   #7
Quote Originally Posted by dumbledore View Post
Not sure about working at all but everything feels like it is working and even.
Old 24-11-2018   #8
Brakes - other brake hydraulics
Euro want over 150 for it...
Ziggy
Meet Bumble-Bee
Old 24-11-2018   #9
You don't have a picture of what to look for do you?
Old 24-11-2018   #10
Ziggy
Do you know why this is the only place when you search for the item that this comes up. EBay is a completely different part
Old 25-11-2018   #11
Quote Originally Posted by Mighty2000Mouse View Post
under your car?????????
theres non any on ebay i looked for you
did you read my post??????
Old 26-11-2018   #12
Sorry just ignore me. After reading your post and then going out I found it and did as you said with spraying it
Old 27-11-2018   #13
Managed to get the part fixed for 45 at a garage. They also sorted the airbag light and my handbrake which I also failed the MOT for so luckily not too painful of a fix
Likes Del80y liked this post
Old 30-11-2018   #14
flisko has donated!
u got mk1?
flisko is offline Reply With Quote Quote
(T) Load sensing valve hcloseuk Doblo 0 20-05-2018 19:41
(T) 1988 ducato rear brake sensing valve linkage MAUBRI Ducato 7 14-12-2016 12:57
(G) Ducato rear brake load sensing valve setting plate . wheelnuts Ducato 1 03-11-2014 20:51
(T) Location of load sensing valves! chs605 Punto (Mk2/2b) 2 10-01-2010 21:03
(T) brake load sensing valve steinar Punto (Mk2/2b) 1 06-11-2008 12:29
