FIAT Auto Specialist Team
Old 19-12-2018   #31
jonik has donated!
Finland
Re: Supercharged Fiat Punto mk2 1.2 8v #boostedpunto
Exhaust sound part 2
www.youtube.com/jonik1
jonik is offline Reply With Quote Quote
Old 23-01-2019   #32
jonik has donated!
Finland
Relocated wideband lambda and assembled oil catch can
Next I will make a new 2,5" cat back to awaken the extra horses, old was Supersprint 1 3/4"
Old 05-03-2019   #33
jonik has donated!
Finland
Made new 2,5" cat back exhaust, much more power on high revs
But the exhaust sound was way too loud. So I installed another silencer and now it sounds great
Ecumaster Det3+ installation:
Full part list:
Aisin AMR500 Supercharger 500cc per revolution (From Nissan)
2" Boost pipe & hose kit
Greddy type RS dump (blow off valve)
Intercooler (Biltema)
Walbro 255lph fuel pump
AN6 adjustable fuel pressure regulator & fuel return line
Injectors IWP127 231cc/min (Ford KA turbo)
COOLINGMIST WATER METHANOL ADJUSTABLE BOOST PRESSURE SWITCH DEVILSOWN NOS
Ecumaster DET3 piggyback
PLX DM-6 Gen 4 wideband lambda gauge
Dragon Gauge analog boost meter
Colombo & Bariani Fast Road Max camshaft
40mm bored throttle body
Ashley exhaust manifold
Old 05-03-2019   #34
Netherlands
Thanks for the update! (and making me look bad)
I'm waiting for the temperatures to increase and the weather to be nice before I start working on my car, and here you are working outside in the freezing cold!
Likes jonik liked this post
1987 Panda 1000
akumabito is offline Reply With Quote Quote
Old 12-03-2019   #35
Croatia
How are you mapping it? Still on stock ECU?
AnteLo is offline Reply With Quote Quote
Old 12-03-2019   #36
Odd question as I’m not 100% but, do you need/should you put a dump valve on a supercharger, they will produce a specific amount of boost for each revolution of the engine and so the air taken by the cylinders will always match that delivered by the supercharger, so my understanding is, that it should never be able to overboost.
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 13-03-2019   #37
jonik has donated!
Finland
Quote Originally Posted by AnteLo View Post
Yes stock ECU, I have Ecumaster Det3+ piggyback
Likes AnteLo liked this post
Old 13-03-2019   #38
jonik has donated!
Finland
Quote Originally Posted by AndyRKett View Post
Odd question as Iím not 100% but, do you need/should you put a dump valve on a supercharger, they will produce a specific amount of boost for each revolution of the engine and so the air taken by the cylinders will always match that delivered by the supercharger, so my understanding is, that it should never be able to overboost.
You're right, the boost should be stable. But still I needed one, car would stall when idling (when throttle valve is closed). So dump must be open when idling and that made it very challenging to find a dumb that works. I tried 3 different dumps, current one is best so far but not optimal.
Old 27-03-2019   #39
jonik has donated!
Finland
New videos
Technics:
Drive footage:
Smaller pulley for supercharger:
It's nice when you can cruise speedo maxed out 😁
punto hgt mk2 supercharged thebear1986 Tech Talk 0 21-03-2012 22:31
(G) turbocharged/supercharged punto? dj_mtbiker_no1 Grande Punto 17 21-08-2008 17:09
