Hello guys. I have a 2004 Punto mk2b, 1.3 Diesel Multijet with a Robotized gearbox. The radiator fan kicks in (starts) everytime I turn on the engine, even in the morning when the engine is cold. I have checked and replaced: the thermoresistor mounted on the fan bracked (new part, OEM). I have changed the relays, checked the thermostat, the coolant temperature sensor works fine, cooland level OK, air bleeding done twice. No errors on the diagnosis tools. Did anyone encounter this issue or has any solution? Thanks!
