FIAT Auto Specialist Team
Thread Tools
Old 15-08-2018   #1
Ecu versions
Hi all.
Long story short. Coil pack ĎAí went but changed both coil packs, ht and sparks, but code still on ecu and car running on 2 cylinders. Lumpy idle, slow pulling away etc
Anyway...my car is a 2006 punto 8v 1.2l the ecu in the car is IAW 5AF.P4
(61601.69.03) HW303
I know if I change a second hand unit I need to change the bcm, key, etc but I canít find a complete kit on eBay.
I can however find a complete kit with the ecu being IAW 5AF. P3 from a 2002 1.2 8v...............
will this work?
Whatís the key difference between the two ecu units? If the problem is just that the older unit will give less fuel economy then Iím a swap it. Obviously if my unit is for abs and the other unit isnít then I wonít swap it...
Thanks.
Other than that my next question on here is If i can get a stand-alone P4 ecu anyone on here that can Virgin it for me or know anybody that can ??? Preferably in South Wales
Kevtherockstar is offline Reply With Quote Quote
Old 16-08-2018   #2
Re: Ecu versions
I donít know what the rules are on bumpy but looking for a quick answer. As without a car at the Mo sorry
Old 16-08-2018   #3
Burkina Faso (Upper Volta)
Re: Ecu versions
you need the p4 or the car wont run right
the other one you quote is possibly for a car with only a camshaft sensor being on an 02
i used to send these away to be virginised took a few days but looking the other week i cant find my link,i used to pay £35
the run out ecu like yours equates to a windows 10 so assume early versions were windows 95
you have the later engine too with the crankshaft that doesnt have a key
s and b is offline Reply With Quote Quote
Old 16-08-2018   #4
chris3234 has donated!
Re: Ecu versions
If you can live without out the car for a week or two try sending the ECU to be repaired
chris3234 is offline Reply With Quote Quote
Old 16-08-2018   #5
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Ecu versions
Early had single lambda
Later models like 2003 / 2004
Had 2x lambda and a camshaft sensor....
So cant swap tronics
Also if you did a full swap
There will be mileage issues depending on what donor and urs is at
Apprenrly the ecu driver can be repaired if need be
Ecu testing for example
Ziggy
Thanks Sjvarley thanked for this post
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 16-08-2018   #6
Re: Ecu versions
I just created another post , really as an update but a separate issue I think ...maybe... had three glasses of plonk sorry....
Basically I donít think the issue is ecu relate as if I swap plugs the fault goes from coil pack one to coil pack two.
Iíve swapped out the sparks form cyls 2/3 in to 1/4 and still coil pack one issue so I know itís not the spark plugs.
Iíve done a phonic reset just because ... still nothing.
Iíve tried a plug and play virgin ecu...still no fire
Iíve had a compression test done by the garage and confirmed ok.
Thread Tools
(G) Tailgate versions Harllequin Panda (Classic) 13 14-02-2010 18:59
(T) JTD ECU Software versions emzo Bravo / Brava 5 10-02-2009 12:54
1.2 versions Anonymous FIAT Boo Archives 6 29-06-2006 16:43
(G) Likelihood of more versions for the UK? Prestissimo Grande Punto 7 21-03-2006 16:44
(G) Panda Versions petebarchetta Panda 1 18-03-2006 00:00
