Kevtherockstar
- Aug 15, 2018
- 17
- 3
Hi all.
Long story short. Coil pack ‘A’ went but changed both coil packs, ht and sparks, but code still on ecu and car running on 2 cylinders. Lumpy idle, slow pulling away etc
Anyway...my car is a 2006 punto 8v 1.2l the ecu in the car is IAW 5AF.P4
(61601.69.03) HW303
I know if I change a second hand unit I need to change the bcm, key, etc but I can’t find a complete kit on eBay.
I can however find a complete kit with the ecu being IAW 5AF. P3 from a 2002 1.2 8v...............
will this work?
What’s the key difference between the two ecu units? If the problem is just that the older unit will give less fuel economy then I’m a swap it. Obviously if my unit is for abs and the other unit isn’t then I won’t swap it...
Thanks.
Other than that my next question on here is If i can get a stand-alone P4 ecu anyone on here that can Virgin it for me or know anybody that can ??? Preferably in South Wales
(61601.69.03) HW303
will this work?
Thanks.
