Not so.
1. A factory new (virgin) ECU will automatically boot up and transfer the code from the body computer.
2. A used ECU can be made to appear as a new one by changing the hex code in the ECU - virginising. That ECU will then work for any car needing that type of ECU.
3. You can copy the hex code from a defective unit in the car to a used one that is good for that car only - cloning.
ute Ago
Ok so I bought a virgin*ecu*from eBay, same problem with immobilizer not letting car start, eBay seller sent me another and that one does exactly the same thing. Either got a seller who is happy to keep sending out ones that aren't coded properly or am I doing something wrong, I am following the instructions, disconnecting battery etc
