Technical question and i can't seem to find an answer on any of the forum threads.
My Punto is a 1.2 8v Active sport Mk2/B
Starter went Kaput, so went onto europarts website and put in vehicle details.It listed 3 different motors with different Kw and teeth numbers and to select the correct one for my Vehicle (hadn't taken the motor off then so had no idea).
Went onto Amazon and it listed several which it stated will fit my Car when i looked into the specs of them.
I get the KW part as being how much current it draws to work , most seem to be 0.8 or 0.9 KW for the 1.2.
The question is does it matter if you get 8 or 9 teeth, i read somewhere that it makes no difference on the 1.2 8v engine ?.
