My suspects
A - fan common to fail due to seizure and results in fan fuse blowing
B - stat gone lazy/sticking
Aftermarket are poo for some reason yet original fiats are hit and miss espicially during winter where they struggle to maintain heat
C - pumps going slow
Loss of blades / slipping on shaft / seizing bearings
All cause slower fluid movement - too slow and fluid gets too hot and isnt shifted quick enough back to radiator to cool.....
Check if fan spins by hand first of all
Also chck fuses
Then go for bypassing relay and foecing fan on to check its working
Ziggy
Cabin fan is the one you control with knobHi Thanks for all the reply guys,
After some investigating I checked to see if the Fans are spinning the answer is No... Even with the heating on Setting 4 the Radiator fans blades are not spinning..
So I switched the Punto off and try to spin the blades myself I noticed they were extremely stiff to spin by hand?
Does this mean I require a need Radiator Fan?
And what Fuse is the Fan?
Engine cooling is automatically done via the engine ecu
A stiff fan = seized bearing or comms on brushs
Take the fan out and give the bearings a good soak in oil and work it till its free
Id be tempted to hook up battery direct to ensure it can spin up free
Ziggy
Depending on brand of fanTurns out the 30AMP Fuse was Damaged. Replaced that. Since replaced the fuse It does not overheat as quickly.
I try to spin the fan and even use some high temperature silicone grease but I have the same issue the fan is not spinning.
Ill try and remove the fan itself.
Will keep you all updated thanks.
Its just 4 x 8mm wood screw threads and 1 electrical connector
Work the fan with the spray oil - once freed up and spinning free - get the spray grease in to keep it freed up
If you were near to another member they may be able to help
Ziggy
Yes removing it is no worse then a seized fan....If the fan is not working removing it can't make things worse. You are reliant on forward motion to cool the motor. The heater fan in the cabin can help out a little so keep it on. Just remember that if you get stuck in slow moving traffic it may not be able to cope. Keep an eye on the guage.
