FIAT Auto Specialist Team
Thread Tools
Old 23-04-2018   #1
Same old power steering fault
Hi All,
I appreciate that this topic has been covered several times, to say the least, but I'm concerned about the possible cures, as I am unable to consider the worst case scenarios.
I have a basic code reader and I think it was code U1700?
My power steering has failed completely, driveable but very heavy.
City function seems to be stuck on.
Steering is normal with no warning light first thing in the morning, but instantly goes back to faulty.
My question(s) is, should I look at
Steering motor?
Steering ECU?
Relays?
Steering column?
I cannot afford to purchase the software and I cannot afford calibration.
I understand it must be frustrating to see people ask the same question over and over, but its probably not as frustrating as having a faulty car that you cant afford to repair.
Many, many, many thanks in advance
adamwills1982 is offline Reply With Quote Quote
Old 23-04-2018   #2
Brendan W has donated!
Ireland
Re: Same old power steering fault
Have a read of this for starters. Post #4 in particular.
https://www.fiatforum.com/punto-ii/4...-steering.html
Check the earth strap from the gearbox, the battery negative connection including the piggyback wire and under the steering column there is the main power plug for the steering. That is worth a clean and reseat.
How good is the battery?
Post #26 in this
https://www.fiatforum.com/500/219810...failure-2.html
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Old 23-04-2018   #3
Many thanks.
I'll start checking those things tonight and keep you updated.
Old 23-04-2018   #4
Re: Electric Power Steering Failure
Ref the steering concern (will produce a U1700 error code, power steering node can not communicate with the body computer via CAN) and odds on will also detect a battery voltage issue in the ABS Module
The starter motor clicking out is also a known related concern ive found along side the steering concern
Check your battery and ull prob find you have a 250 or 300 both of which have been modified part numbers to 350 now.
Tou to get it changed under warranty the midtronic's used by your dealers will require the battery to state that its faulty and require replacement (Most of which do). Others may simply require a good charge
But from experience of these, Battery always fixes both concern's
Worst case scenario, have had 1 where the starting concern had gone un-reported and the starter motor chewed up the ring gear... Ended up needing a new starter, flywheel and battery
Does that refer to the amperae of the battery???
Old 23-04-2018   #5
Ireland
Most likely it refers to the battery CCA or amps delivered at cold cranking.
2001 1.2 8v
Old 11-06-2018   #6
Sorry for the very delayed response.
After checking the fuses and spraying all the connections, and putting a bigger battery on, touch wood, The power steering fault appears to have been resolved.
Many thanks for the help
Old 12-06-2018   #7
I cant believe I tempted fate by posting that last night. Low and behold, the power steering just failed!!!!
Old 12-06-2018   #8
The main issue is you’re trying to fix a problem blind and on a shoe string, you need to accept what ever the cause, somewhere along the line you are going to need to spend some money.
You’ll need a new battery, a new steering motor or to get the codes read or buy the stuff to read codes yourself, these systems don’t throw up faults for no reason at all and it’s almost unheard of that you can fix the fault with a bit of contact cleaner.
The other thing to consider is that if you are continuing to drive the car, then as it stands it’s in an unroadworthy state.
There have been people on this forum who have had very serious accidents because of transient steering problems, switching off power halfway round a corner.
It really isn’t something you should be playing about with in the hope it goes away.
From your other posts regarding knackered suspension bushings and broken window problems, it sounds like a shed, you can’t scrimp on safety critical components, you could kill yourself or at worst someone else
Likes Eklipze3k liked this post
Maker and voice behind the YouTube channel PuntoHowTo
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 12-06-2018   #9
Burkina Faso (Upper Volta)
without knowing the year and model of your car there is no way it can be even considered that you can be helped on an internet forum
s and b is offline Reply With Quote Quote
Old 12-06-2018   #10
I appreciate your feedback, and apologies, I thought I had stated the year make and model.
Its a 2004 punto 1.3 16v Dynamique. Although it doesn't sound like that matters now.
Having replaced the battery, I genuinely am not in a position to be able to spend more on a car that could continue to go wrong.
Old 12-06-2018   #11
also, I have access to a code reader, which gave U1700. Thats not specific enough is it?
The mot is up next month, I only paid 350 for the car and the front bumper needs replacing and it has airbag failure warning. Is it worth even contemplating looking at the work?
Old 12-06-2018   #12
varesecrazy has donated!
Quote Originally Posted by adamwills1982 View Post
the same diagnostic kit to read the PAS will tell you why the Airbag light is on,
front bumper shouldn't be MOT fail in itself. unless its REALLY loose , or a danger to pedestrians.
so - where is the "Renault interiored" Punto based..??
I'm around Oxford .. and Cardiff
Cardiff / Oxford
Old 13-06-2018   #13
Moderator
g8rpi's Avatar
g8rpi has donated!
Hi read other posts on this fporum about the faults. For steering try the jumpsleads between battery negative and chassis and engine block test.
Airbag light is MOT failure too. There are common issues, again do some searching, reading on here.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 13-06-2018   #14
If the steering issue is intermittent, how will I know if the jump lead test works?
ie, if the steering is currently ok, as it is now, the jump lead test would show any difference would it?
Old 13-06-2018   #15
Moderator
g8rpi's Avatar
g8rpi has donated!
Correct. You need to carry the jump leads and try them if the fault appears.
Robert G8RPI.
Thread Tools
(T) Power Steering fault PandaMark Panda 4 30-03-2017 00:46
(T) power steering fault Mark H Punto (Mk2/2b) 10 05-04-2011 21:12
(G) Power Steering Fault cosso1 Stilo 24 16-03-2010 01:56
(T) Power Steering Fault CraigGraham Punto (Mk2/2b) 1 27-08-2009 17:45
