My power steering red light intermittently comes on but I have never had the steering fail. I have read loads of threads especially the excellent guide. I have checked the battery and alternator and I suspect the alternator is just on the cusp of failing/under performing.
It starts fine and I have no alternator battery warning light. Below are the readings I have taken, can you advise if you think it is the alternator and if so I will get it swapped or do you think its actually something more serious popping the EPS light on?
Battery test
Cold first thing in morning 12.6v
Crank it and it does not go below 10v-11v
Alternator test
On tick over with no load I get 14.2v
On tick over with all lights on, main beam, blower on 4, rear demister on I get 12.65v to 12.78v (this is the reading I think is not so good as the guide says no lower than 13.8v and possibly the cause for the red light?)
Rev to 1500rpm on full load and it goes to 14v
Do you think that alternator is good or borderline or just faulty?
I have cleaned the earth up to the body, cleaned battery terminals, checked all connections are secure on alternator, belt tension.
Punto 2004 1.2 8v petrol.
Battery test
Alternator test
