Has anyone of you FF peeps ever Removed the HGTs Injector wiring loom off before? (Wiring also connects up the coil packs, MAF etc, goes along fuel rail and joins to injector connection ports to fire them off)
I need to change it over and have gotten 99% of it off.
There’s just one more bit just where the loom earth point that attaches to the back of the engine & starter. There’s a smaller bit of cable attached to part of the earth cable that goes from that under the rear plastic manifold that sits under the fuel rail.
Has anyone accessed it before and how did you remove it? It’s proving difficult because of the tight engine space to see where I’m removing it from. I don’t have any pics atm of it but can do tomorrow if it will help explain what I’m on about lol.
Thanks in advance
Thanks in advance
