BlackWooZ
Member
So while i was driving i noticed that my driver side high beam wasn't working.
The next day i went to check up by changing the bulb, but that didn't fix the problem, wiring and connectors inside headlight are intact so i went to check all the fuses in case some of them blew out, but they were all fine visually...
All of the lights work except drivers side high beam for some apparent reason.
Any idea?
And by the way, while i was bolting my headlights back in.
Somehow, i don't know, magically the hole of ''chassis'' where it bolts in literally snaped? like someone cut'd perfect square under, which shocked me the most!
Is metal made that cheaply?
Any idea?
