- Aug 14, 2015
- 72
- 15
Hi'
1.2 16v, year 2000.
Last day, I started of from work to drive home.
Instantly at least one cylinder was missing.
"Ok, its the coilpack", so changed it.
And the battery, since at was not doing very good already, for some time.
Nothing was better ! :-(
Checked leads and sparkplugs.
Spark on all four sparkplugs.
Sparkplugs on cylinders 2 and 3 a little dark, but works fine.
Interchanged the leads. Nothing different.
Interchanged the sparkplugs. Nothing different.
Only cylinders 1 and 4 is working correctly.
Tried cutting power to the injectors.
When I remove the powercable to the injector on injectors 1 and 4, the engine halts.
When I remove the powercables to injectors 2 and/or 3, the engine humps along as before. So no reaction if power is connected or not to injectors 2 and 3.
With ignition on, all powerconnectors to the injectors show 8,5'ish volt's.
So there is power to all four injectors !
Either exhaust or cylinders smell like unburned fuel.
There is no (new) strange smell in the engine bay.
There is no raise in oil usage and oil looks very fine.
There is no use or drop in coolant and its the same pretty colour as always.
So..., what can cause two injectors to quit, simultaneously?
PS: I cannot do a compressiontest, and absolutely nothing indicates headgasket failure or failure to pistons/valves !
Thanks in advance.
BTW: No warninglights are active, but they work when ignition is turned on.
Temperature is good and stable, also.
1.2 16v, year 2000.
Thanks in advance.
