I had the fan stop working in my 2005 fiat punto active sport back in summer, busy with work I got time to sort it yesterday, replaced the resistor and cut the earth wire either side of the connector (it had melted inside the connector block) and put a straight through piece of wire in. It worked great until I came to start this morning the fan kicked in for at most 2 seconds then shut off, I've checked fuses, resistor and the earth wire I cut and soldered all are fine with no restriction to flow....
any ideas ?
Thanks in advance
Jens
any ideas ?
Thanks in advance
Jens
