Tuning Mk2 turbo HELP
Hi all this is a one for a few forum veterans.
Have been running my 1.2 8v on 7psi boost but wanting a bit more boost, currently I have been using a single injector mounted in the inter cooler pipe above the inlet, now my question is how did the likes of Mankul and brin mount there injectors (only people I know of) I know my system is a it outdated but the MF2 is capable of up to 14psi but I'm thinking maybe 12psi at most as I have a coupe 20vt for when I need big boost
Thanks Connor
It's basically to run a bit more power, when I've read his build last night and he was able to run 20psi through it, I'm not looking at massive gains just more reliability as it's starting to lean out at wide open
Any more info or pics of your setup? I've been thinking of turboing mine :D
Yeah my engine is currently out for some tlc and some upgrades
There's already a diy thing on another site to get the parts but no info for the assembly process but all parts are available and you can even modify a toyosport manifold for the turbo itself I'm using a gt28 of my coupe with a 7psi waste gate as I'm having fuel issues but I'll get some photos when I go to put it back together IMG_0187.JPG
